I just went through a small disaster repair because the hot wire from the electronic ignition retrofit on my '65 was
cut by the bottom of the ignition shielding. As it shorted to ground it took out my ignition wire back to the switch
thus days of pulling the dash and repair. Ugh.
Now that everything is back together I wish to make sure that none of those hot wires ground out again. There
are several opportunities for this if you look closely. Has anyone found a sure way to insulate these wires from
long term harm?
The other problem is the "lag bolt" that holds the ballast resistor to the firewall has stripped out the firewall glass
and is very loose. Any good fixes for that?
Steve
long term harm?
Steve
