TI Ignition
  • Mark L.
    • August 1, 1989
    • 518
    #1
    TI Ignition
    ti ignition mark lincoln while at the national convention i had the pleasure of having the ti amp fail when i was taking the car off the trialer does anyone have any experience with the new style module that can be installed in the ti box by the way i'd like to publicly thank lou r mike m and dick w for their help in gettng the problem diagnosed and fixed that's one of the things that makes ncrs such a great organization
  • W Gibson
    Re: TI Ignition
    re ti ignition w gibson i had my t i amp restored and updated by dave fielder it s as close to new as possible
    • TREBOR M
      Re: TI Ignition
      re ti ignition trebor m replaced one in a lt it is solid state and you can use any type coil you prefer it is very easy to replace the hard part is getting the box out another advantage is that if a plug does quit firing you dont run risk of blowing it good luck
