On my '73 there appears to be the remnants of a black tar sealant on the firewall and inside the wiper compartment in front of the windshield. It has badly deteriorated and has dried and cracked. Much of the material has fallen out.
It was used to seal the seams where the AC/Heater (passenger side) and power brake booster (driver side) join the firewall. It was also used to completely cover the wiper pivot brackets that are bolted just under the windshield. This also appears to be the same material that is used to seal the seams in the wheel wells.
The sealant is described in the Tech Info Manual & Judging Guide as:
"This sealant is a thick black asphalt-like material that often is not carefully applied.", Pg 90.
I use to work in the Ft. Wayne and Pontiac GMC truck assembly plants and remember that a similar black tar sealant was used on the final assembly line (i.e. after the body emerged from the paint shop oven). This sealant looked like roof repair sealant that you would buy at Home Depot and was applied to seams that could be exposed to corrosive liquids such as water mixed with road salt. However, I cannot find a similar material being sold in any of my Corvette restoration/parts catalogs. I have several questions pertaining to this sealant:
- Can this sealant be purchased anywhere? If not, does a material like black tar roof sealant serve as a replacement? (i.e. the black roof sealant that is sold in caulk tubes at any home repair/improvement store)
- Does anyone know exactly where, how much, and how thick this sealant should be applied in the engine compartment and wheel wells of a '73? What are the judges looking for here?
- Is the sealant applied before or after the paint is applied to the engine compartment and inside the wheel wells?
Thanx,
-Floyd-
Thanx,
-Floyd-
