midyear A/C "leaker" fix sealant - NCRS Discussion Boards
  • Brandon K.
    • April 1, 1997
    • 474
    Anyone know what a good sealant to use is on the top of the A/C box on the firewall so it doesnt leak? I can see a small visible gap under the plenum (despite brand new gaskets) and it will definitely leak if not fixed. I'm sure the original stuff is no longer available. Thanks! Brandon
  • Jim T.
    • March 1, 1993
    • 5351
    Re: midyear A/C "leaker" fix sealant
    I can recommend 3-M Strip Chaulk. It is usually carried at well supplied auto parts stores and always at the places where body shops buy their paint and other supplies. Comes in a flat rectangular box and the chaulk is in thin strips and is paintable. Lots of uses on Corvettes.
    • Doug Flaten
      Make sure you doen't use anything along the joint that will prevent you from parting the box for service. I made that mistake years ago on a Mustang heater box, and ended up cracking the fiberglass trying to open up the box.
