Bird Cage Repair - NCRS Discussion Boards
Bird Cage Repair
  • Tony Roussos
    Bird Cage Repair
    Has anyone experienced the situation of having to repair a rusty birdcage? For example: Finding a rustout on the door jamb. How involved was the repair in terms of time, cost, and what was done to make it right?
    Thanks.
    Tony
  • Jerry Clark
    Re: Bird Cage Repair
    Plenty in the archives on this
    Lots of all, time money and expertise is required. The rusted section , (depending on amount, should probably be replaced by a professional unless you are VERY talented
    jer
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Ditto what Jerry says
      If your handsy and have a well equipped garage, then your a step ahead.
      My 68 was so bad, even though I could have repaired it, I opted to pick up another rust free body for what I know was way less than what I would have had into it in parts, money and last but not least sweat equity.
      Best left to the pro's if your not deep into mechanics and body work caus it will require both...............Did I mention plenty of patience too?
      Chuck 32205
      • Tom Sarno
        Re: Ditto what Jerry & Chuck says
        Chuck is right, the time spent fixing it should be spent looking for a rust free body. if there is rot in the lower kicks, then there is probably rust in other areas that you don't see yet.
        Chuck, tonight I finally got the last parts of the rear suspension on my frame so it is able to roll on its own for the first time in years! Now I start rebuilding the body. Its been a long time since we emailed each other about possible rust repair options.
        Tom Sarno
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Hey Tom
          Just ordered a small boat load of fresh brake and suspension parts for the beast.
          With my rust free California frame, Colorado rust free body, and all these new goodies, I might actually be able to have the Zora's brain child rolling around the yard in about oh say .........another couple of years at the rate I'm getting my "Honey Do" list worked down
          I'm getting all kinds of hyped up now Dude!!
          Chuck
