C3 Door switches - NCRS Discussion Boards
C3 Door switches
  • don justham
    C3 Door switches
    Are the door jamb switches at the rear of the door supposed to be spring actuated. The ones at the front side of the door that actuate the courtesy lights are spring actuated. Maybe my rear ones are worn out because they stay "in" all the time. Are these for coutesy lights or for the alarm system? Thanks
  • Kevin Whiteley
    Re: C3 Door switches
    I have a 68 with no alarm and I have the rear switches. I think they may be for the "Door Ajar" warning light.
      Don and Kevin-----
      The plunger switches on the lower rear door jamb area are for the "door ajar" light and, on cars so-equipped, also the alarm system. These switches were definitely spring loaded. They are not the same switch as the forward door jamb-mounted courtesy switch light, but they operate the same way.
      • Harmon C.
        • August 31, 1994
        • 3228
        You should save your old switches if original as some owners have found ways to use the old pin with the letters, on new switches. Lyle
        Lyle
        • Kevin Whiteley
          Are the "SX" pins reproduced?
          • Reba Whittington
            The only reproductions I have seen are blank on the head and have a diameter larger than the original "SX" ones.
