mid year hood help - NCRS Discussion Boards
mid year hood help
  • David G.
    • December 1, 2002
    • 99
    mid year hood help
    I recently acquired a 67 coupe. the hood will not stay shut, if car goes over bump, door slams etc, I am not near a good corvette repair shop. where can I get proper procedure to adjust springs, cable, posts, etc?
    Dave
  • Michael H.
    • July 31, 1998
    • 180
    Re: mid year hood help
    Hey Dave -
    It would be a good idea to invest in a Service Manual for your car. Try taking a big flat blade screwdriver and turning the spring posts on the underside of the hood. They will lengthen or shorten depending on which way you turn them. There is a slot on the point that the screwdriver fits into. Good luck.
    • Scott Butville
      There was recently a very long thread on this subject on the Corvette Forum. Suggest you do a search over there.
      • Jim T.
        • March 1, 1993
        • 5351
        There was also a recent recent post here about this problem. I believe it mentioned that if the spring latch is compressed, to tight, that this would permit the hood to unlatch. So try backing off on the adjustment a couple of turns and see if this helps.
