Hi everyone, I just replaced my brakes on the 1975 singray.
New o-ring calipers (from vbp of course) new rotors.
I used the speed bleeder in conjuction with the gravity method.
Brakes seem to work good but on every caliper one side of the pistons seem to be all the way in the bore not even touching the pads. On the right rear the caliper body is grinding away on the rotor. Is there a difference between the front and rear rotors? cause my new ones had no part #'s to speak of and the rotors look to be identical.
