Help! I've got a 65 on which I just had the gague cluster restored. The ammeter doesn't work. I've disconnected the plug on the gague and checked for voltage on the wires. Both of them show battery voltage. After searching on this board, I checked for resistance across the gague (with the wires disconnected) I got a reading of 0.00 milliohms. Somewhere on here someone stated that it should be approx. 500 milliohms. I checked this against my 67 (whose ammeter works) and got the same results. What gives? Is there any other thing to check? I've got this bad feeling that the gague is bad and I'll be pulling the cluster again.
Dan
Dan
