1975 CONVT PAINT CODES - NCRS Discussion Boards
  • Stephen E. Mueller
    HELP:
    I am looking to purchase a 75 convt. The only problem is the paint/trim codes. The trim tag reads as follows paint 22L and trim is 73v which equal brigt blue on dark red. This is not standard, can this car be a COPO? I know the car's tag is correct backed up by a build sheet! Would this make the car more valueable?
    Steve
  • Kevin Whiteley
    Re: 1975 CONVT PAINT CODES
    Value is very subjective. My personal opinion is yes and no. It could be more valuable to some, who may really like or desire the "non-standard" paint/trim combination. Yet, since it is "non-standard" combination, others may view it negatively, hence a lower price/value. If you like it then thats all that matters. I believe that the build sheet would identify it as COPO if it was.
    • Harmon C.
      • August 31, 1994
      • 3228
      Steve W hat I have seen on the build sheet is customer ordered on non suggested interior colors. It did not require a COPO. Lyle
      Lyle
        Kevin:
        Can you tell what the best way to identify if it is a COPO? Also the trim tag reads as follows TRIM 73V 22 L Paint F-26. What does F-26 Mean?
        Steve
        • Greg A.
          • June 30, 1998
          • 141
          F-26 is the body build date...in 1975, F = March, so your body was mated to the chassis on March 26, 1975 and probably rolled off the assembly line a day or two later.
