The end play on my distributor shaft was .009 (1965 069 distributor). I don't remember the end play specs, so I set it to 001. Can someone confirm the range--I think it is .002-.007, but not sure.
There is a dimple on the dist. driven gear, but is it supposed to coincide with the rotor contact? My driven gear has 2 dimples: 1 is more like a centerpunched mark between the teeth of the gear itself, on the bottom of the cog, near the oil pump drive. ; 2 is a much more pronounced depression, about 3/4" above the top of the gear, on the flat area just above the gear, but on the gear "assembly". The funny thing is this: I HAD THE ROTOR CONTACT ALIGNED WITH THE DIMPLE ON THE GEAR TOOTH (although it did not align perfectly with the rotor),AND WAS ABLE TO TIME THE ENGINE. TODAY I PULLED THE DISTRIBUTOR, SEE THE LARGE DIMPLE, TURN THE COG ABOUT 165 DEGREES, AND BINGO, PERFECT ALIGNMENT WITH THE ROTOR CONTACT. So, which dimple should I be looking at, and how should it be aligned with the rotor contact.
Thank you.
Thank you.
