Any '72 owners and/or judges with knowledge of this solenoid, your answers would be appreciated. This solenoid is on '72's only, and is mounted to a stud sticking up from one of the intake manifold bolts on the passenger side, inboard of the passenger side valve cover. It is a vacuum solenoid that feeds/monitors vacuum from the carb to the distributor. My car was suppose to have it, but when I bought it, the solenoid was missing. I located one through Corvette Central and received it today. Question is...there appear to be three vacuum ports on this solenoid, but only two vacuum hoses. On the front of the solenoid is a "T" shaped fitting, with two of the ports. One is for the vacuum line coming from the carb, and the other I believe is for the vacuum line going to the distributor. On the backside of the solenoid is another port, which I do not know the purpose for. Anyone know?
Kevin #39927
Kevin #39927
