Fusible Links - NCRS Discussion Boards
Fusible Links
  • Chuck G.
    • May 31, 1982
    • 2029
    Fusible Links
    Does anyone know of a source for these ? I checked all of my old Corvette parts books and cannot find them listed as separate items. I don't recall ever seeing them in the trade catalogs either. Were they considered part of the harness ? If one burned up on the car, (doing their job) they must have been able to replace them. Any help appreciated. Thank you. Chuck
  • Bill Clupper
    Re: Fusible Links
    Chuck, a limited array of Fusible links were serviced through the Standard Parts catalogue, or may also be available as part of a kit of electrical items from Kent-Moore. (Detroit) They were also used in every GM car and Truck from 1967 until very recently, so there is a large supply in salvage yards.
    • Bill Clupper
      Re: Fusible Links
        Re: Fusible Links
        Chuck----
        Basically, fusible links are simple a section of wire that is of larger gauge(smaller diameter) than the wire or circuit it protects. Fusible link wire in 50 foot rolls is available from GM under the following part numbers:
        12077140---10 gauge
        6293923----12 gauge
        6292995----14 gauge
        6292996----16 gauge
        6293702----18 gauge
        6292997----20 gauge
        12077141---22 gauge
          Re: Fusible Links
          Chuck----
          12077140---10 gauge
          6293923----12 gauge
          6292995----14 gauge
          6292996----16 gauge
          6293702----18 gauge
          6292997----20 gauge
          12077141---22 gauge
          • Gary Bishop
            Re: Fusible Links
            I was able to buy a couple of feet from my local Starter / Alternator rebuilding shop.
            • Gary Bishop
              Re: Fusible Links
                Re: Fusible Links
                You will also find them in various lengths and gauges at any NAPA store - I have added them to every Vette I've owned, all of which were '65 or earlier; a burned-up main harness (and maybe the car with it) is not a pretty sight. All you need to remember is that a fusible link is designed to protect a power circuit two sizes larger than the fusible link (for instance, a 14 gauge fusible link will protect a 10 gauge circuit, 16 gauge will protect a 12 gauge circuit, etc.) Just measure the actual gauge of the power feed wire from the (large) terminal on the starter solenoid, and get the corresponding size fusible link (which includes the large lug for the connection to the stud on the solenoid). Cut the existing power feed wire back, splice in the fusible link using a crimped butt-joint connector (slip a piece of heat-shrink tubing over it first before you splice, then heat the shrink tubing after you crimp the joint to seal it). I view this as a safety issue - who's ever going to un-wrap your power feed wire to see if they can find a splice anyway?
                  Re: Fusible Links
                    Re: Fusible Links
                    On early Sharks, the common ones to go live in the engine compartment and attach to the B+ buss bar on the side of the horn relay. You'll find an 'infinite' supply of correct originals at your local scrap yard on Chevy passenger cars of the era....
                      Re: Fusible Links
                        Re: Fusible Links
                        Later (Shark era) fusible links would be visible external to the harness forming a loop with 'pregnant snake' section color coded for link capacity. So, depending on application/position, just cutting a dissimilar gauge length and butt splicing it inside the harness strategically may not get the factory concours job done...
                          Re: Fusible Links
                          • Bill Clupper
                            Re: Fusible Links
                            I'm sorry but I have to disagree on the colored "snake belly" It is black on all applications except a very few instances in '67 when clear was experimented with. The capacity (amperage) is coded by the size of the main lead, to which the smaller "fusible" wire is spliced. The black Mold covers the splice. The color of the fusible section may vary, but generally will be the same for equivalent current capacity from a GM pass car of the same year as a Corvette. Some years used different colors on the fusible portion for different capacities, some did not. If you are looking at a specific year, I might be able to give exact information, depending on the year.
                            • Bill Clupper
                              Re: Fusible Links
