This has been going on for quite some time, and I'm about ready to throw in the towel. Here is a summary, which some of you might remember.
Car is 1965 with close ratio, 3.70, new Borg standard diaphragm type, 365 SHP. Everything on the car is new or rebuilt--car has a total of 57 miles since completion. Just got carb back from Jerry Luck, who did an outstanding job. Distributor rebuilt with new shaft, bushings, etc--end play set to .004, zero wobble, no discernable plate wobble, special hi perf points as per Duke's recommendation (which DID cure a high RPM breakup problem). Dist set to spec, and tested for proper vac advance/cent advance deployment--oll AOK. Delco "44" plugs, which all show dry and grey-tan after hot laps. 30-30 correctly set as per Duke/John H method. Lifters no longer clack, but "sing" sweetly. Vac @ idle (800RPM)= 10.5 in-hg. Valve springs new, measured at 100 pounds - valves on seats. Heads pocket ported, CC'd (opened to 67 cc's), intake gasket matched/ports polished. Carb stock, and as delivered by Jerry Luck. Compression tested @ 195psi +/- 5, across all 8.
The car screams at high RPM, shift points @ 6200 RPM, no breakup, still pulling hard. THE PROBLEM IS that I've got to slip the clutch to get the car rolling from a dead stop. If I don't slip it enough, the RPM's drop, and it will stall unless I pump the gas. Is this normal, or am I expecting too much.
Sorry for the lengthy post, but I tried to give you all a clear picture.
Appreciate any help here.
Joe
Joe
