If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
The bellcrank assembly that bolts to the bellhousing to block area was common to the chevy pass cars of the 55-57 and possibly later era. junkyard time. mike
Don't know if you're talking about the floor shifter (lever) assembly, the rod to the trans lever, or the kickdown linkage assembly, but if a junkyard doesn't pan out for you, Paragon and CC both have the floor shifter assembly, and CC has all the rest of the linkage parts.
There is a 58 Impala in a bone yard near me.If that kick down and bell crank will work I'll be happy to gather them for you.
I have no idea if they are the same but I'm certain someone here will know.
Rob
The bracket that mounts to the manifold is different on a 1X4 and 2X4 carb setup. You can make the 1X4 bracket fit, but it is not correct. The rest is the same on cars, vettes, and trucks.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
