I would like to know of any reputable suppliers that would be able to help me secure a rebuilt or "new" carburator for my 327/365 HP 1965 vette. Date code is not as important as functionality. Any recommendations out there? Thanx.
Replacement Carburator for 1965 365hp
Re: Replacement Carburator for 1965 365hp
Pete,
I'm in the same boat but have limited my self to a 2818 (date not important). Have you looked at the holley 3367 from 1966 or the 3810 from 1967? I missed a NOS 2818 that sold for $280. I've heard the 3811 will work too.
I've also heard that your run of the mill 1850 with proper jetting is a suitable replacement and there are tons of them out there.
There is what appears to be a new 3367 on Ebay for $350. I have no idea what "new" means in this case. Holley still sells the 3367 as part of their O.E. muscle car line.
I've never even owned a holley so read with caution! I'm sure some others will weigh in.
Brian- Top
Pete:
Any Holley 585 CFM model 4600 will work. Just be sure to install 122-65 primary main jets, and 122-72 secondaries, with a 065 power valve. Go to www.holley.com to check the specs.
If you want to spend the big bucks for a model 2818, then try Jerry Luck. He might have an improperly dated service replacement carb in inventory that he can prepare for you.
Joe- Top
Thanks, new to the Carb situation. Went to the Holley web site, saw a 600 CFM/ model 4160 and 585 CFM / model 3367, not familiar with 4600 - also - additional rookie question: mechanical or vacuum secondary?- Top
