Just a quick question before I start removing things I should refrain from...
Is it possible to replace the long front-to-left block brake line on a 1967 car without removing/lifting the body structure? I have found the rear crossover line to have encountered someone in the past and shall require replacement; insofar as I have replaced every other brake line (unfortunately in a piecemeal fashion) on the car and shall need to bleed the rear section anyway, is this feasible? Or another case of my "trying-to-fix-what-isn't-broken"?
Thanks!
Carl
Thanks!
Carl
