Valve cover gasket - NCRS Discussion Boards
Valve cover gasket
  • John Werner
    Valve cover gasket
    79-L82 What did the factory use for the valve cover gasket.
    Re: Valve cover gasket
    John----
    1979 Corvettes, both L-48 and L-82, did not use a traditional cork gasket. These Corvettes used Silicone RTV, GM #1052366, instead of a gasket.
      John----
      • John
        Thanks for the information. I would rather use a gasket, but will this take points away?
        • John
            John----
            I can't be of much help with respect to the potential loss of judging points; I don't know if NCRS/NCCB protocols call for this feature to be "judged". It would be difficult to detect whether or not a carefully installed gasket had been used in place of RTV, though. Especially, if one were to use one of the thin, black composition gaskets available from Fel-Pro. These don't seal or last anywhere near as well as the thicker, steel cored Cork-Prene, but they won't stand out like those, either.
            Having said all that, the RTV silicone "formed-in-place" gaskets can seal VERY well if installed properly. I recommend using Permatex "Ultra Black" instead of the GM sealer I previously mentioned. This is a much newer technology sealer that will seal OIL very well, and looks IDENTICAL to the original GM sealer.
              John----
