When the speedometer cable comes through the firewall on the engine side, is it suppose to be bent at a sharp angle downward and "wedged" behind the ignition shielding? I don't see any other way to route it.
Why is one hole larger than the other on the top of the front engine mount bracket? The hole on the passenger side is larger on my bracket. The bolt diameter appears to be the same on both sides.
What type/size of firewall grommet is used to route the radio ground wire through the firewall?
What type/size firewall grommet do I need for the wiring harness (generator/voltage regulator harness)? I tried to figure out which grommets to purchase from Dr. Rebuild, but could not based on catalog descriptions.
