C2 w/strip sealer - NCRS Discussion Boards
C2 w/strip sealer
  • John Thomas
    C2 w/strip sealer
    Could someone please advise a good substitute for the sealer for the w/strip to body hinge pillar on a 67 coupe. The assembly manual calls for "Sealer-reclaimed rubber".
    Thanks in advance
    John
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: C2 w/strip sealer
    John, if you're talking about sealing a stainless steel weatherstrip retainer to the windshield pillar of the bird cage like on my 70 coupe, a good substitute (identical as far as I can tell, except for color) is 3M "Strip Calk". It is available at body supply stores in a flat, long box filled with strips. The original material was a soft, pliable, non-hardening putty-like material. "Strip Calk" has the same characteristics, but is black in color.
