I need someone to measure the distance from the gasket surface on the back of a power booster to the end of the brake pedal rod. The booster should be off a C3, mine is a 72. I'm having a fitment problem and can't get it figured out.The measurement should be around 6+ inches. Also,does the very end have a screw adjustment where the attachment end goes to the brake rod?
Thanks in advance
Thanks in advance
