1962 electrical problem
  • Earl Chapman
    #1
    Just recently put in a new wiring harness. Now when I press the brake pedal the gas guage goes over to full. Also I when turn the turn signals on the gas guage jumps every time the signal flashes.Have tried new turn signal switch, still same problem. Any suggestions? Thanks.
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: 1962 electrical problem
    Earl - Very thoroughly check every ground attachment on your car. After you do that, check them again. There will be some gauge spiking on a '62 due to inadaquate (sp) rear grounding from the factory, but what you describe is over the line. Best, Dennis
    • Rob Dame
      If you can't find the bad ground run a separate ground wire from the sending unit to some inconspicuos place on the frame.
      Rob
      • Ed Jennings
        That's probably the ultimate fix for all C1's.
        • Dennis A.
          • May 1, 1999
          • 1010
          Earl...
          Adding the Tank ground sure worked for me.
