C1 (62) Shifter Floorpan Cutout - NCRS Discussion Boards
  • Ed T.
    • November 1, 2002
    • 95
    I am looking for a drawing, photo, or description indicating the size and position of the 4-speed shifter floorpan cutout in a C1 (62). Someone chopped a big hole in my floorpan. Probably to remove the shifter from aboce. Now I am replacing the transmission tunnel, but the replacement panel has no hole. Any help would be appreciated...Ed
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1 (62) Shifter Floorpan Cutout
    Ed...
    If you can locate were the shifter console plate screws into the two retainer nuts, the plate can be used as a guide. I well overlay my 61' tonight and let you know some dimensions.
    • Ed T.
      • November 1, 2002
      • 95
      Thanks, Dennis. The transmission tunnel ashtray well is still there, and I think the screw holes for the plate...Ed
      • Dennis A.
        • April 30, 1999
        • 1010
        Ed...
        If you insert the ash tray into the shifter console plate, then seat the ash tray into the tunnel, the console plate makes a perfect template for marking the cutout. I was surprised how close they match up.
        • Ed T.
          • November 1, 2002
          • 95
          Hi Dennis,
          I will need to get a new console plate, as someone sawed mine in half (front to back), leaving the ashtray half, but not the shifter hole half. Working on these old wrecks is sure a lot of fun.
          If you have your console plate out, could you fax me a templete showing the outline of the ashtray hole and the shifter hole. My fax number is (609)466-4116. Thanks...Ed
          • Dennis A.
            • April 30, 1999
            • 1010
            Four-speed on the way *NM*
            • Ed T.
              • November 1, 2002
              • 95
              Re: Four-speed on the way
              Thanks, Dennis. Got the fax. That is exactly what I needed. Thank you very much...Ed
