Re: 65 Disk Brake Woes
Does you comment that "the brakes are deplorable" mean the front brakes do not work correctly?
The problem you seemed to be descibing is the rear brakes would work somewhat but would not release and return to their normal position (hot brakes). The fronts were being applied and releasing in a normal manner.
If there is an obstruction, as I suggested, that is preventing the rear pads from releasing rather than bad calipers, loosening the bleed valve will allow them to relase. If they can be moved, and the front brakes are ok, it is likely an obstruction in the line. If they cannot be moved it is the calipers.
If it is an obstruction you may need to disconnect the two ends of the line and blow it out with clean air. Which of course means you will need to rebleed the brakes.
If the front brakes are not properly working the answers may change...
Dave
Dave
