1968 Electrical and vacuum routing - NCRS Discussion Boards
  • Mike Baker
  • Kevin Whiteley
    Re: 1968 Electrical and vacuum routing
    Mike,
    I believe you are correct in the order - engine harness, TI harness, and vacuum lines. I think this issue is mentioned in the TIM& JG, but I can't find a reference to it now.
    If you have TI, there should be two holes in the radiator core support. The upper hole was pre-existing and routes the vacuum lines and forward lamp harness. The AIM indicates that the lower hole was drilled for the TI specifically, and routes the TI harness.
    • Mike Baker
      Thanks *NM*
