Weight of 327 block ? - NCRS Discussion Boards
  • Mark Milchuk
    Going to pick up a 327 Block.
    Can some one tell me how much the block weighs.
    It is just the block. No heads, no intake manifold,
    no pistons.
    It is a short block complete with oil pan and balancer
    How many people would it take to lift the block
    or is that out of the question and I should rent
    an engine hoist?
    Trying to figure out the best way to load
    and transport the block.
    Thanks Again to all that help,
    Mark
  • Kevin Whiteley
    Re: Weight of 327 block ?
    I'm not sure of the exact weight, but 2 could lift it with some difficulty onto a pick-up bed. If the seller has an engine hoist - use it. If not, try to get at least three people.
      Mark-----
      In your post, you mention that it is "just a block" and excludes, among other things, pistons. Then, you say that it is a short block which includes pan and balancer. When the term "just a block" is used, that infers that it is a BARE block. A bare block is just that----only the machined block casting with main bearing caps; NOTHING ELSE.
      A "short block" or "partial engine" is, generally, considered to be a block which includes all internal block components, but, usually, excluding oil pan and balancer. Pistons are ALWAYS included as part of a short block assembly.
      Anyway, a BARE small block of PRODUCTION configuration weighs about 185 pounds. To that, you'll need to add the weight of whatever other components that this block contains.
