1968 427/390HP Engine Installation Advice - NCRS Discussion Boards
  • Henry J.
    • November 1, 1999
    • 457
    I will be installing my freshly rebuilt engine soon and would like to benefit from the collective experience of the general membership in order to ensure a good job of it.
    Currently the bellhousing and 4-speed transmission are still in place on the car.
    Which is the preferred course of action? Should the engine, bellhousing and transmission be assembled outside the car and installed as a complete unit or should the engine go in separately? For your information, I have an excellent engine lift apparatus, good tools and plenty of skilled help.
    Your advice is much appreciated. Thank you.
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 1968 427/390HP Engine Installation Advice
    Should be no problem mating the engine and other components in the car. You may need a helper to guide and help align the trans input shaft while you work the hoist.
    • George Daina
      you might have to....
      rotate the input shaft to mate with the clutch spline, other than that, it's a walk in the park. Only way to pull the motor...why create more work for yourself. I'll never yank the tranny again, when pulling the motor.
      George
      • Henry J.
        • November 1, 1999
        • 457
        Re: you might have to....
        Thanks Wayne and George. I appreciate your advice.
