67 Frame Stencil meaning - NCRS Discussion Boards
  • Robert M.
    • May 31, 2000
    • 42
    What do the white stenciled numbers on my frame mean. 303196-33-(6 or G) C and 3900200-4-20-67. My car is a 67 conv. 427 L68. Trim tag says I26, St. Louis car with vin 7154.
  • Kevin Whiteley
    Re: 67 Frame Stencil meaning
    Keith,
    303196-33: A.O. Smith p/n, for 1967 there were -30, -31, -32, -33, & -34 series.
    GC: abbreviation for Granite City, Il, where A.O. Smith plant was located
    3900200: GM part number, should be in appropriate year AIM.
    4-20-67: Date frame was manufactured, in this case, April 20, 1967.
    According to Tripoli's book, the frame stencil should be 1" in height upside-down on the passenger side, and could resemble the following:
    3900200-33
    303196-1-18/GC
    but this isn't always the case. If yours does not resemble this, don't worry. Could you please post how yours is painted on?
    • Frank H.
      • May 22, 2013
      • 148
      Re: 67 Frame Stencils ??????
      Stencils I have seen are all one piece with the letters lined up even at beginning and parallel and 3/4 inch , originals I have seen ,its obvious that top and bottem stencil are separate with random spacing and not lined up even at the beginning,top one being applied at granite city,like the top sample in the book having not received the lower stencil and date at the plant,called a mystery.
      bottem sample ,the jan 18 one deferenced, letters are staggered at the beginning and first and second line not perfectly evenly spaced, suggesting two separate stencils
      The Jan 18 stencil you list, car was probably built first week of Feb or about 10 days
      earlier same as yours
      • Kevin Whiteley
        Re: 67 Frame Stencil Correction
        Frank is correct about the height being 3/4". 67's frame stencil's were 3/4" in height, while 68 and later years (to at least 72) were 1" in height. My apologies for any confusion.
        As far as the rest, I don't have any information regarding spacing, letters lining up, etc. The sample I listed was taken from Tripoli's book and was used as an illustrative example.
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1464
          Where did you get the VIN of "7154" from? Does...
          not match the other dates.
          • Kevin Whiteley
            Re: Where did you get the VIN of "7154" from? Does
            Michael, I didn't even catch that. VIN 7154 would have been built around very early January 67, which clearly doesn't match the frame date of April 67.
            Keith, is the VIN derivative on the frame 7154?
            • Robert M.
              • May 31, 2000
              • 42
              I don't know where January came from. The body tag says I26 and the vin is 117154. The frame stencil date is 4-20-67. All other pars n the car are dated coded March or April.
              • Mark G.
                • March 1, 2001
                • 227
