T-top leaks - NCRS Discussion Boards
T-top leaks
  • Tony Roussos
    T-top leaks
    I've heard it a million times: "They all leak!"
    Well, I'm open to your experiences with solving the notorious leakage problem.
    I seem to have a leak in front and back. The front leaks drip on the center of the floor mat where the knees would be. I suspect the water runs down the pillar sides, finds it's way past the door seal to the bottom of the dash.
    For the rear leak, I suspect the water follows the top channel line in the chrome trim to the back arch, then seeps through mini cracks in the arch before drunning down the bottom.
    Does any one have a sure remedy for what ails my favorite machine?!
    Thank you.
    Tony
  • Warren F.
    • December 1, 1987
    • 1516
    Re: T-top leaks
    Tony: I have replaced the T Top weather seals and adjusted the tops to a better fit to rid my water leak problems. The T Tops can be adjusted in several directions. I have successfully done this to 3 '70 & 2 '71 model Corvettes. Usually widening the center gap and making it perfectly equal in width helps alot.
