C-1 choke - NCRS Discussion Boards
C-1 choke
  • Jon S.
    • November 1, 1992
    • 202
    C-1 choke
    Can anyone briefly describe how the welch like plug installs on the bottom of the piston cylinder of the choke base. (wcfb, 3191s, 62, 250hp) Thanks in advance.
    Jon
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: C-1 choke
    if it is a new one just tap in the center to expand it and if it is a used one i have used non hardening perm a tex but i took the choke pulloff piston out first to make sure the was no sealer in the piston bore. you could also use epoxy.
    • Jon S.
      • November 1, 1992
      • 202
      Re: C-1 choke
      Thanks Clem for your quick response. It is a new one. When I tap in the center to expand it, should I use a small punch or small faced hammer or some other special tool?
      Best regards, Jon
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: C-1 choke
        i just tapped the convex part with a hammer in the center.
        • Jon S.
          • November 1, 1992
          • 202
          Thank you Clem! *NM*
