C1 Rear Springs
  • Gary A.
    • June 1, 2001
    • 86
    #1
    C1 Rear Springs
    I have a bent rear spring on my 1959. I was thinking of installing the rear spring kit from Corvette Central while having the originals either repaired or replaced. Has anyone used these. Comments or suggestions are always greatly appreciated.
  • Mike M.
    • June 1, 1974
    • 8288
    Re: C1 Rear Springs
    Gary: if you're referring to the rear spring liners for a c-2, vet products of michigan supplied mine several years ago. they were nearly identical to the originals. CC may get them from vet pro of mi. good luck, mike
    • Gary A.
      • June 1, 2001
      • 86
      Re: C1 Rear Springs
      Mike; CC has a kit that includes the springs, hangers, bushings and all the hardware to install. I was curious as to whether anyone has used these and if they are worth using over the 40yr old ones as to ride, safety etc.
      • Dave Suesz
        C1 Rear Springs
        To repair the original spring, they must be dissasembled, annealed, arched, and heat treated. Cold re-arching dosn't hold up. Assemble with new liners and bands. Top leaf silver, others black. Then overspray with chassis black, quickly, as though you were spraying the chassis in a hurry.
        • Larry P.
          • July 1, 1999
          • 481
          Re: C1 Rear Springs
          I purchased rear springs for my 60 from CC about 3 years ago. They had the body sitting way to high. A guy fom CC told me to install 2" spacers to get the body back to level. Not happy!
          Larry
