Warning: Undefined array key 942 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
C3 - Ignition Switch Replacement / Trim Tag Q -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I'm working on a 1974 Corvette and the ignition switch is bad. Can someone please tell me how to replace the ignition switch? I have a tilt & tele column. How do I get the old switch out?
Also, Where can I purchase a repro trim tag? My tag was removed years ago.
It is not easy to replace these switches as they are located on the lower end of the steering column's upper surface. You must lower the column to replace. This was done intentionally for theft prevention reasons. In any event, the complete procedure will be found in your 1974 Chevrolet Service Manual. You shouldn't be even attempting any repair (especially, one like this) without having and following the procedure in the Chevrolet Service Manual. For 1974, this is a somewhat expensive publication, but if you want to work on your own car, you must have it. You can get one at the NCRS bookstore.
Steve The igniton switch bolts to the outside of the column with two screws between the lower dash and the firewall. It should be easy to remove and their is some adjustment that could be your problem. It has a rod going to the key lock assembly. Lyle
There is a great deal of information on the assembly and dis-assembly of the tele-tilt steering column for C3s posted at www.corvettefaq.com. This is courtesy of Jim Shea. Take a look (click on "steering") and I'm sure you will find something to help.
