Template: page_preheader
Template: includes_fontawesome
Warning: session_start(): Session cannot be started after headers have already been sent in /home/ncrs/public_html/forumtest/includes/vb5/frontend/controller/page.php on line 71 Template: screenlayout_display_full
Template: page_header
Template: page_head_include
Template: hook_hide_default_subnav
Template: hook_addtobookmarkthatrocks_css
Template: page_data
Template: top_menu_sitebuilder
Template: top_menu_user
Template: login_main
Template: ad_header
Template: ad_header2
Template: search_popup
Template: notices
Template: screenlayout_row_display
Template: screenlayout_section_display
Template: screenlayout_widgetlist
Template: widget_pagetitle
Template: module_title
Template: widget_conversationdisplay
Error (8): unserialize(): Error at offset 0 of 3 bytes in phar:///home/ncrs/public_html/forumtest/core/vb/vb.phar/library/user.php line 2.
Error (8): unserialize(): Error at offset 0 of 24 bytes in phar:///home/ncrs/public_html/forumtest/core/vb/vb.phar/library/user.php line 2.
Template: hook_timedsticky_message
Template: conversation_toolbar
Template: pagenavnew
Template: toolbar_filter_menu
Template: pagenav
Template: display_contenttype_conversationstarter_threadview_Text
Template: display_contenttype_threadview_header
Template: noderead_data
Template: conversation_userinfo
Template: avatar
Template: userlink
Template: pmchat_userinfo_link
Template: hook_topic_starter_ribbon
Template: display_sharing
Template: conversation_signature
Template: display_contenttype_conversationreply_item_deleteinfo
Template: inlinemod_checkbox
Template: display_contenttype_customfields
Template: ad_first-post
Template: display_contenttype_threadview_footer
Template: conversation_posthistory
Template: conversation_footer
Template: taglist_display
Template: reactions_conversation_footer
Template: hook_postfooter_bookmark
Template: hook_gototop
Template: display_contenttype_conversationreply_threadview_Text
Template: avatar
Template: userlink
Template: display_Comments
Template: avatar
Template: userlink
Template: avatar
Template: userlink
Template: avatar
Template: userlink
Template: avatar
Template: userlink
Template: ad_last-post
Template: pagenav
Template: conversation_data
Template: page_footer
Template: hook_add_footer_breadcrumbs
Template: hook_timedsticky_copyright
Template: hook_starter_ribbon_copyright
Template: reactions_list_template
Template: hook_ajaxinstantsearch
Template: hook_main_nav_dropdown_menu
Template: hook_gototop_click
Template: hook_postfooter_bookmark_click
Template: hook_memberlist_contains_search
Template: debug_info
Oil in the air cleaner...HELP!! - NCRS Discussion Boards
  • Dick Kindl
    All you expert motorheads!! I have a 66 with a 327/350HP. When running at high speeds, (over 60MPH / let's say around 3000RPM), I get a lot of oil in the air cleaner. The oil spills over on the intake after filling up to the lower rim, and the air filter gets saturated with it. My oil pressure is pinning on the gage ..it drops back a little at idle. I took the air-breather tube off( as recommended by a friend) and looked in the hole w/a mirror and was told I should not be able to see the push-rod- and if so, was missing the internal oil breather canister that is supposed to be in that hole. I did see the pushrod so I assume that the canister is missing and this is why the oil is being "sucked" up into the air cleaner. I have obtained such a canister and will be installing it.
    My question? Is this the cause of my problem or should I be looking at other solutions as well? I checked the PCV valve and it is OK. Any help will be greatly appreciated.. Thanks in advance....DICK
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Oil in the air cleaner...HELP!!
    buy a genuine GM PCV valve as some aftermarket ones cause all kinds of problem including oil burning
    • Mike McKown
      I won't say the missing baffle is causing your problem but it is likely aiding and abbetting it. If memorey is correct, the PCV valve is in the oil fill tube at the front of the engine and is plumbed to a vacuum source on the carb or intake. The flow should run out of the fill tube into the vacuum source with fresh air vented through the rear of the crankcase which is piped to the air cleaner. If you have oil in the air cleaner, your flow is reversing for some reason.
        Dick-----
        In the PCV system used for your engine, filtered air is drawn from the air cleaner through the tube in the rear of the block, into the crankcase, and then out through the line in the filler tube to the vacuum fitting at the base of the carburetor. However, the lifter valley mounted "cannister" is really an oil baffle designed to prevent the "reversion" of the oil mist ever-present in the lifter valley of a running engine from "back-flowing" into the air cleaner. If this baffle is missing from your engine, then that's a really good potential culprit for exactly the problem you're dealing with. I' definitely install it at once.
        Your high oil pressure problem is likley unrelated to this problem, but it may constitute another problem in itself and for other reasons. The first thing that I'd do is to hook up an accurate test gauge to determine if you really have a high oil pressure problem. If you do, we'll go from there.
          • 15610
          What you refer to as a "cannister" and (I think) GM calls a "ventilator" functions as a liquid vapor separator, and if it is missing I would expect oil in the air cleaner.
          Removing the manifold to place the device there should solve the problem, and you should also research the appropriate service manuals and AIM to insure that your PCV system is properly configured with proper routing and parts.
            Addendum
            Dick-----
            One other thing: even with the cannister/oil baffle installed, don't expect the "oil-in-the-air filter" problem to go away completely. Under certain engine operating conditions, some of the oil will get back through the system and into the air cleaner. These baffles just aren't that efficient.
            In 1968 the system for small blocks was revised so that the rear of block breather was eliminated and "intake" for the PCV system was moved to the right side valve cover and the "suction" moved to the left side valve cover. Baffles in both valve covers were supposed to prevent the excessive escape of oil. They weren't too effective, either, and GM changed the design of the baffles 2 times to help improve the situation. The problem was never solved, though, and some oil will usually be seen in the A/C. My 69 has been doing it since the day it was new and even though I "upgraded" the valve covers twice to take advantage of the "new and improved" oil baffles.
