65 automatic - NCRS Discussion Boards
65 automatic
  • Don Heckenberg
    65 automatic
    I am looking for someone with a 65 automatic (also AC would be a bonus). What I need is some info on the hole in the radiator support that the transmission cooling lines go through. Also some info on the routing of the AC vacuum lines through the firewall (going from the coolant shut off valve to the switch). Thanks for any help you can give, Don H.
