C3 Vacuum advance 1968 - NCRS Discussion Boards
  • Jim T.
    • March 1, 1993
    • 5351
    Removed my distributor to check out the tach drive damage. After removing the distributor shaft I laid the distributor down with the original vacuum advance can's vacuum connection nipple facing down. Later I noticed that oil had drained out of the vacuum advance from the nipple. Anyone experience this before?
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C3 Vacuum advance 1968
    Jim,
    No, where do you have your vacuum hose pluged into?
    Also do you have a lot of oil in the air cleaner?
    Will the diaphram move with a vacuum source applied?
    • Jim T.
      • March 1, 1993
      • 5351
      The vacuum line is connected to full vacuum port on the Holley spread bore carb that I put on the car in 1973. I have never had any oil in the air cleaner. The vacuum advance checked out ok with engine vacuum and a vacuum tester.
