Spark at Battery - NCRS Discussion Boards
Spark at Battery
  • Dan Rosczyniala
    Spark at Battery
    When I connect the battery cable to the battery the first contact gives off a large spark then diminishes to a smaller spark. My first thought is the clock, but I have not done any checking as of yet. I planned on introducing a VOM between the battery cable and post. Then hopefully by pulling fuses I can identify the circuit and ultimately fix my problem. Anybody had this, any ideas?
  • Eugene B.
    • May 31, 1988
    • 710
    Re: Spark at Battery
    Dan,
    You didn't mention what year car you have. Does it have an under-hood light? I encounter this when I connect the battery cable to my '93 Chevrolet truck.
    Regard,
    Gene
    • Dan Rosczyniala
      it's a 64 vert and all accessories are off when this occurs. I do have some issues with fuel and temp guages not working but I would assume that would not show up with the key off. Thanks.... Dan
      • Wayne P.
        • August 31, 1975
        • 1025
        What about your interior lights or your gloves box light? Glove box lights have flattened many a battrey!
        • Dan Tewell
          Dan, Try disconnecting your voltsge regulator. I just found this draw on a 65. Replaced the regulator, all fixed.
          • William V.
            • December 1, 1988
            • 399
            Dan
            On my 64 I have accidentally left the ignition switch in the ACC position and ended up killing the battery. It's easy to do when you turn the car off by reaching through the driver window. Just a thought.
            • Dino L.
              • February 1, 1996
              • 694
              I second that...I thought I was the only person in the world that could kill a battery by leaving the ignition switch in the accessory position...just did it last weekend AGAIN. You can teel I hav en't been driving this car in years
              Dino Lanno
              • William V.
                • December 1, 1988
                • 399
                Dino
                It's just that we are the only two that will admit it.
                Bill
