has any one used a 4 terminal replacement relay from mary jo rohner if so what lead gets a jumper? thanks
1954 replacement starter relay
Tags: None
- Top
Re: 1954 replacement starter relay
Hi Chester. If you've got a 4 terminal replacement, here's the way they do it. Look at the relay as it would be mounted on the car. You'll have 2 horizontal "prongs" coming out at 3 and 9 o'clock, and 2 vertical prongs coming out at 6 o'clock. The vertical prong on the RIGHT side gets cut off, and is "jumped"/soldered to the other vertical prong. They use heavy wire....10 gauge or so. Chuck1963 Corvette Conv. 327/360 NCRS Top Flight
1956 Chevy Sedan. 350/4 Speed Hot Rod- Top
