My late '73 AC compressor is equipped with a '74 inlet/outlet block. This block has the schrader fitting located on the left side port, as viewed from the back. This port I believe is the suction line to the compressor from the VIR. The right block port goes to the front of the radiator to the condenser. The VIR has a schrader fitting on the top. Both fittings are the same thread. As I understand the AC system the high pressure side, many years ago, had a smaller schrader fitting so as not to get the high and low pressure connections mixed up.
Anyway the question at hand is how to I measure the high pressure side of the refrigerent system, or is that even necessary? I have been told to measure both the high and low pressures to ensure that the system is working properly.
Roger
Roger
