c2 back up lights - NCRS Discussion Boards
c2 back up lights
  • john pickens
    c2 back up lights
    My restored 65 327 roadster has always had the reverse light lenses in
    place, but I discovered recently that they do not function when shifted into
    reverse(this vehicle is a 4 speed ). In checking the assembly manual, I see
    no sign of the switch for reverse lights mentioned. I have checked the bulbs
    and they are fine. How does one determine if the vehicle is so wired, and
    then how is this problem to be investigated? Seems I read that the backup lights were not standard until mid 1965. Thanks.
  • William C.
    • May 31, 1975
    • 6037
    Re: c2 back up lights
    The switch for the backup lights mounts on a bracket attached to the transmission side cover. Two wires run from the switch up tp a 2 way connection Behind and inboard of the valve cover on the drivers side in the engine compartment. The switch is activated by a lever connecting the lever on the switch to the reverse arm on the trans.
    Bill Clupper #618
    • Jack Layton
      Did your car leave the factory with back-up lights ??? An indicator clue would be the presence or absence of a "day-night" mirror. The two items were sold as a package. So if you have one of the two then you should also have the 2nd.
      • Mike Yager
        If you do need a switch, make sure you also get the small heat shield for it. The switch mounts to the side of the transmission in a location that is very close to the exhaust pipe and needs the heat shield to keep the protective coating on the switch from melting.
          John -
          You'll find the illustrations and part numbers for all the backup lamp components in the back of your '65 Assembly Manual; Section Z01, Sheet 1 and 2.
