This is probably a dumb question, but.... I replaced the ball joints on my 66 and now I'm wondering if I installed the upper joints correctly. The replacement joint purchased from LIC was essentially a one piece unit that I mounted on top of the a-arm with the joint extending down through the hole in the a-arm. My question is should it be bolted on the top side or on the underside of the a - arm? Thanks for any help.
John
John
