My '72 has chambered exhaust, and they are a little too loud for me. At some point in the future...hopefully, not too distant future...I plan to install a complete set of aluminized mufflered exhausts. My car is very original, including the original 2" exhaust manifolds. It has been my intent to make/keep it that way. As I see it, I have two options 1) replacing the chambered system with a "more stock" 2" system (including mufflers with 2" inlets and outlets) would put it back to stock, but what if I do not like the sound of the repro mufflers? I believe I am then stuck with a system that I could not go to a set of turbo (or like high perf. mufflers) because the pipes are 2", and it seems most high perf. mufflers have 2-1/2" inlets. 2) I could install a set of 2-1/2" pipes, with a 2" coupler to the exh manifolds, and a 2" section at the end for the tips, and with a muffler with 2-1/2" inlet and 2" outlet. This would solve problem in #1, but would not be stock, as the pipes would be 2-1/2".
Is there a real performance advantage to having 2-1/2" pipes over 2", if your manifolds and tips are only 2"? Do the judges "doc" you for having 2-1/2" pipes on a car that should have 2"?
Kevin #39927
Kevin #39927
