We are looking for help/guidance with the following questions. Our car is a 1969 427/400 tri-power 4-speed with factory air. We are missing the fast idle solenoid set-up that mounts to the front carb. Looking for suggestions on who might carry this. The second question involves our intake manifold vacuum fitting. It has two outlets. One goes to the power brake booster. The other is capped off. Is this the correct fitting, and if so, where does the second outlet on the passengers side go? We have the assembly manual, but it doesn't show up in clear enough detail. The third question involves the factory alarm system. We need the clip that holds the flasher, the flasher itself, and the relay. Any ideas on who would carry this? We saved the best for last. It involves the wiper motor/washer pump assembly. The pump on the drivers side has the outlet nozzles broken off. Also, if anything goes with this, it is missing also. Any ideas where to locate this? Thanks in advance for any help.
Frank & Paula Lowery NCRS #28045.
