68 seat belt installation - NCRS Discussion Boards
  • Scott Tilley
    I'm installing new seat belts in my 68 convert. Does the belt that's bolted to the floorpan under the seat, mount under the carpet or on top of the carpet? Also, the lap belt runs through a reinforcement plate that bolts to the side of the floorpan. Is this part supposed to be chromed? Mine is. Thanks for the help. Scott
  • Reba Whittington
    Re: '68 seat belt installation
    The seat belt mounts under the carpet. The retainer is either chrome or stainless steel; it has been a long time since I looked at one out of the car. I don't know if you are replacing carpet also, but there should be a vinyl
    grommet in the carpet for the belt to pass through.
    • Mike Baker
      Reba and scott,
      Are you refering to the reinforcment plate that bolts to the floor under the carpet or a tensioner for the belt?
      • Reba Whittington
        I am referring to the plate that mounts over the retractor/tensioner and forms a track for the seat belt to come through the carpet.
        • Scott Tilley
          I am replacing the carpet. The carpet is from Al Knoch, but does not include a vinyl grommet for the seat belt to pass thru. I think the original carpet did, but unfortunately I think I through it away thinking it would be included with the new carpet. Thanks for the response, I thought it should mount under the carpet but wasn't sure.
