C-1 Voltage Regulator ID? - NCRS Discussion Boards
  • Joe Maulsby
    I purchased a voltage regulator from a salvage yard in the late 1980's to get the Delco cover. I noticed it is stamped with P/N 1119 001D and the date code is OE. The 1960 JM shows the part number to the the same as a Corvette part, but no reference to the "D". And the build date "OE" does not make sense. What vehicle did this part originate on?
  • Mike E.
    • February 28, 1975
    • 5134
    Re: C-1 Voltage Regulator ID?
    Joe,
    The OE does make sense-- 1960/May This came off either a Corvette or passenger car, and is a 30-amp regulator.
    • Terry Leeker
      Following up on the Reg. question. Were '58 Vette regulators the same as the '58 passenger for the same amps?
