While doing a little pre-car show cleaning on my 1966 smallblock coupe, I had one rear wheel jacked up off the ground and the other on the ground. I noticed I was able to rotate the raised wheel fairly easily. I read in a previous post that there should be some resistance to the raise wheel spinning if the positraction unit is working properly. I'm pretty sure the car has posi (i.e. it has the little red plastic tag on the fill plug), so I have a couple of questions.
1. Even with the motor not running, and hence no input torque, will the posi unit create friction between the two rear axles?
2. If there is supposed to be some resistance and mine doesn't have any, could this be a result of not having the GM posi additive in the rear end? I had my mechanic change the differential fluid over the winter, but now I'm not sure he put this in. Can I add this "after the fact"?
3. Does driving in small figure eights help this situation?
3. If the posi unit is just worn out, is it a big deal to replace it? Is the Eaton unit I see advertised a good replacement? Is this a "bolt on" operation?
4. Is there a downside to having a worn out positraction unit other than being able to "burn rubber" easier than I would otherwise (I never do this, of course). The car is never driven in inclement weather.
Thanks.
Thanks.
