67 327 engine bracket colors - NCRS Discussion Boards
  • Chuck
    Hi,
    For a 67 327, does anyone know the correct color paint for the distributor hold down clamp wire? How about the square washer? bolt?
    Also, anyone know the correct color of the alternator bracket, semi-gloss black? the alt bolt through bracket?
    Thanks, Chuck
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 67 327 engine bracket colors
    Chuck:
    Hold down assembly is black, and the bolt is black phosphate.
    • Chuck
      Thanks for the quick answer! Alt bracket is black too.
      Thanks, Chuck
      • Gene M.
        • April 1, 1985
        • 4232
        Your small block upper alt. brkt is black the lower one is orange as it is loose on the engine when painted.
        • Chuck
          Then bolt must be orange too, correct?
            The bottom bolt on the lower bracket (the one that's shown in the A.I.M. to be loosened, then re-torqued after alternator installation) was installed at Flint Engine, so it was painted with the engine; the other bolts and the upper brace were installed at St. Louis.
            • Mark H.
              • July 31, 1998
              • 384
              Same for '64? *NM*
              • Joe C.
                • August 31, 1999
                • 4598
                Yes *NM*
