WSW Pump Guts - NCRS Discussion Boards
WSW Pump Guts
  • Tony H.
    • May 31, 1993
    • 537
    Re: WSW Pump Guts
    Thanks for the tip. I will checkout the local scrap yards for some of these gems in the rough.
    Tony
    • Tony H.
      • May 31, 1993
      • 537
      Re: WSW Pump Guts
      Tony
      • Chuck G.
        • May 31, 1982
        • 2029
        #18
        Re: WSW Pump Guts
        Sounds like a deal to me!!! Unfortunately, I don't have the pump anymore. See you at Vintage Thunder in a few weeks. Chuck
        • Chuck G.
          • May 31, 1982
          • 2029
          #19
          Re: WSW Pump Guts
          • Tony H.
            • May 31, 1993
            • 537
            #20
            Re: WSW Pump Guts
            I did a couple of things today regarding pump restoration:
            First, I went to the scrap yard and got two spare piston/cylinder mechanisms from a 71 and another later GM car for $5. These were 3-port pumps that I could use in the event mine was not salvagable.
            Second, I found that in addition to the broken cylinder wall, the solenoid which activates the plate to allow the piston to move and create the pumping action had slipped about 1/16", just enough to cause the mechanism to jam. I discovered this gap by comparing my original with the two that I brought home from the junk yard. This may have been the reason that the cylinder wall eventually failed.
            Third, I moved the solenoid back into the proper position and used JB Weld to hold it in place forever. While I was at it, I decided to use JB Weld to fix the cylinder wall breakage. Tomorrow I will install the restored pump and let the Board know how everything turned out.
            Just in case, does anyone have a junked 5-port WSW that they would like to part out a cyclinder case. I'm not yet out of the woods. Also, was this a Corvette only, one year wonder(ful part)? I wouldn't mind having a spare.
            Tony
            • Tony H.
              • May 31, 1993
              • 537
              #21
              Re: WSW Pump Guts
              Tony
              • Tony H.
                • May 31, 1993
                • 537
                #22
                Re: WSW Pump Guts-Other GM cars?
                What other GM cars/trucks of the era featured a headlight washer system?
                Tony
                • Tony H.
                  • May 31, 1993
                  • 537
                  #23
                  Tony
