How much movement is there in in the heat riser valve? The counterweight on mine sits horizontal (when cold). I can only push it down about a half an inch. It doesn't go vertical. I saw in the archives that it should have 90 degrees of movement. Is that accurate?
C2 - Heat Riser Valve
Tags: None
- Top
Re: C2 - Heat Riser Valve
Take the heat riser off the car and using krol or wd-40 or some such lubricant,gently loosen up the pivot points with the heat riser in a vice and you manualy working the flap valve back and forth till you have about 90 degrees of movement. then go for it. good luck, mike- Top
Sometimes a heat riser valve which is "freely" moving on the work bench will become "cocked" or twisted upon installation and then "bind" so that it will no longer open 90 degrees after installation. The cure is to be sure that the valve is properly aligned as you tighten the nuts. BTW : Brass nuts if it is a non-judged car.- Top
Thanks for the advice. Since I've got to take it off anyway, I've ordered one of the spacer plates and plan to remove the heat riser valve since I don't need it for the carb I'm running now.- Top
Steve----
From a functional standpoint, you're better off in most situations without the valve or with the valve wired open. Even for judging, I'd go with a valve with the butterfly plate removed. These valves are the cause of the "early demise" of right side mufflers on C2 and C3 Corvettes.In Appreciation of John Hinckley- Top
