More 69 AIM questions - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1580
    Evening all,
    I can't read the following part Numbers
    UPC: L36
    Sheet: A7
    Title:427 Pulleys & Belts
    ItemS: 1,2,3,12,13,14,& 15
    Can't read the part name either
    UPC: L71
    Sheet: A6
    Title: 427 3X2 Carb. Link.
    Item:1
    part names ?
    UPC: M20
    Sheet:A6
    Title: 4spd trans. interlock linkage
    Items 1 & 5
    part names ?
    UPC: M40
    Sheet:A3
    Title:3spd Auto. Trans
    Item: 1
    This info should keep me typing for the next week or so
    Thanks in advance
    Don
    Re: More 69 AIM questions
    Don-----
    L-36, sheet A7:
    1= 180122----BOLT
    2= 103321----L. WASHER
    3= 3919886---BRACE
    12= 3889372--- PULLEY ASM-WATER PUMP
    13= 3937771---CLUTCH ASM-FAN BLADE
    14= 9419030---BOLT
    15= 3740523---SPACER
    L-71 sheet A6:
    1= 3931076---CLIP
    M-20, sheet A6:
    1= 3960620---CLIP
    5= "part of transmission asm"
    M-40, sheet A3
    1= 3876439---BUTTON
    • Donald O.
      • May 31, 1990
      • 1580
      Thanks Joe, You da man!
      Can you also read on,
      UPC L36
      Sheet A7
      Items 21 Bolt & 22 Generator
      Don
        Don-----
        L-36, sheet A7:
        21= 3792380----BOLT
        22= 1100833----GENERATOR
        • Donald O.
          • May 31, 1990
          • 1580
          Thanks Joe *NM*
