Does anyone know of a procedure to test the fan clutch ? The only method I know of is to check how much effort is required to spin the fan by hand when the engine is hot (engine off, of course). I believe it should require much more effort to spin the fan when hot. Naturally, mine doesn't seem to change much at all between cold and hot. The temp gauge always stays just to the left of the number "2" in the "210" on the gauge, which I think is about 180 degrees F, where it should be. Do these clutches gradually fail or do they usually just quit ? Any suggestions are appreciated...
Thanks in advance
Craig Jewett # 28049 '67 L-79 A/C coupe
Thanks in advance
